Discuss What type of shower tray in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all.
Sometime ago I removed our old 1200x800 shower tray and replaced with a Stone resin one. The stone resin tray was much, much heavier than the old one. At the time I didn't give much thought to it, but now I'm wondering which type of tray it would have been.
Other than it weighed no more than 10kg, it's other distinguishing feature was the underside of it. It was flat. A board of some description was used to form the bottom.
Which type of shower tray would this have been?
Sorry. I don't have any photos of it
I'm not sure that anyone here will know more about the shower tray that you installed and we've never seen than you do yourself. Do you not have a receipt/invoice from whoever your purchased it from? What about the installation instructions?
Why does it matter if you’ve now removed it?
Anyway, from your description it sounds like a tray by Zamori- this had a metal frame around it and an abs shell they were very lightweight. But I’m sure there are lots of others too…
Reply to What type of shower tray in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
