Discuss General tools in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
rian951
Evening all..!
Just a couple of questions really....
1. I have just bought a used hilmor (15-22mm) pipe bender. Do you have to use hilmor guides or can I buy a set of universal jobbies..?
2. I am due to buy a Rothenberger superfire 2 torch with mapp gas, but any idea where I can get them cheapest? Ebay comes out as about £50.00, does this sound the best price?
3. I have seen a Rothenberger quick jet heat guard (Rothenberger Gas Torch Heat Guard Superfire 2 Quick Jet on eBay (end time 15-May-10 11:58:11 BST)) has anybody used one before, and are they worth it or shall \I just buy a heat mat instead?
Any info would be greatly appreciated..!
Evening all..!
1. Universal should work fine
2. Good price
3. Buy a heat mat instead
monument guides the same as hilmor, using mapp gas will result in a very hot flame so if your inexperienced your better using propane
Evening all..!
Hilmour use a thicker guide. IF using a universal set you better buy a footrule.
Benzomatic is much same as Rothy but cheaper. Rothy is lifetime guarantee tho ;) Forget the MAPP gas.
Waste of money. Learn to solder properly.
Your welcome.
Reply to General tools in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
