Discuss Gerebit Flush Valve too short, any ideas how how to make the button sit higher? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've bought a replacement flush valve for (Geberit 282.350.KD.1 Flush Valve) as the last one fell to pieces, it works perfectly but the top down button is about 2 inches too short to sit in the hole on the cistern lid.
Is there an easy way to get it to sit higher?
You can reach it if you have long enough fingers but it's only a short term solution! Any help appreciated, cheers, Tim
Reply to Gerebit Flush Valve too short, any ideas how how to make the button sit higher? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
