Discuss glowworm 18 home wire programmer? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just fitted a gw18 home. all fires up, only way to get heating is to manually move the leaver on 3 point value, programmer is not connected any ideas on wiring it?
old boiler was glowworm 18 sxi with pump in airing cupboard.
this has been removed as the gw18 had the built in pump.
Reply to glowworm 18 home wire programmer? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler. It has an...
It was fitted with the boiler a Potterton Suprima 30L about 21 years ago. Two PCB's later and a new fan the boiler is working perfectly. However...
1K
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed...
2K
Hi all, My customer has a Honeywell Home ST9500C two-zone programmer. One of these: Honeywell ST9500C 7 Day Two Zone Programmer | Programmers &...
3K
Customer complains of Intermittent heating on Y plan with Stat satisfied. New boiler fitted last year (no permanent live required or fitted...
2K
