Discuss Grant VortexBlue Oil Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Use an S plan rather than a Y plan. BTW with the Grant Vortex Blueflame models, using a Grant G1 accredited installer gives you a full 10 year parts and labour warranty.
Using a firebird VIP installer also gives you the 10year. Not just grant offer this. Id recommend you look into and try the new elco burner on the firebird. The new combi is a thing of beauty.
I wouldn't touch Firebird with the proverbial end of the stick. Grant Blueflame all the way. If it goes wrong, everything is covered fo 10 years
It's great that you actually install and recommend the boiler that I am intending to have installed :D
One quick question for you:
We have recently installed a water softener :cool:
So for filled up the new unvented 'system' boiler (not a Combi) would you use soft water or the regular mains water?
We live in a very hard water area :eek:
For system water it doesn't really matter. It's not going to be constantly refreshing but you keep the same water in for ever until you come to do any work on the system. Always be sure to add inhibitor. If you constantly have to keep topping up, then it may cause a problem, but if that is ever the case, you need to address the root cause anyway.
Reply to Grant VortexBlue Oil Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
