Discuss Grohe Shower runs cold from very high temp start in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Grohe shower Grotherm 1000 smart starts very high temp, then runs cold (28C) in 2 mins
Changed thermostatic cartridge for a new one
Exactly the same problem?
Inlet temp 54 C
Inlet pressure Hot 3.5 Bar
Inlet pressure Cold 3.5 Bar
Any advice appreciated
Jason
You might have the hot and cold feeds going to the wrong inlets. This is particularly likely if it's always done this, or been very sensitive when trying to set the temperature. Some models allow you to install an upside-down cartridge to compenstate for this and you need to make sure you have the right one for your configuration.
Thanks for response, I put the old cartridge back in and now starts up cold when turned to the right and goes hot to the left, hopefully temp will sustain and not drift cold, will test tomorrow.
Also noticed the non return valves look different to replacements, are the photos normal, or do
theses parts need replacing?
Thanks for any advice
Reply to Grohe Shower runs cold from very high temp start in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
M
My house runs an unvented system and I plan to renovate my shower and replacing the existing one with a Grohe Grotherm 1000 Cosmopolitan Bar...
Min Chew
M
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hi Can anyone please give advice on our Grohe Smart shower. It initially starts off hot for 30 seconds then goes luke warm, initially tried a new...
Hi everyone just checking if this is right regarding water pressure and combi boiler pressure: Do hot and cold water always vary in pressure such...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
