Discuss Had an new bathroom fitted - sink blocked, called dynorod out, he laughed, HELP! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all,
We had a new bathroom fitted 3 years ago and the sink blocked up recently, tried to clear it my self (removed basin trap but turned out the gunk was solid in the waste pipe and wasn't budging) got emergency home cover with my house insurance and they sent dynorod out and the feller laughed at how the sink was plumbed in. So, I'm going to the folks that installed the bathroom (they use a freelance fitter) and ask them to make good the plumbing. Really interested to hear you guys and girls opinions on the job as the feller from Dynorod said he'd never seen anything like it.
I've attached a couple of pics, be very grateful for any feedback and especially if you think that the plumbing is OK or not please? Basically the pipe coming from the waste trap was just pushed in and tightening the collar doesn't seal the pipe so water just gushes out. Secondly am I correct in thinking that the waste pipe should have a continual fall after it exits the waste and not have a "rise" in it? Basically the Dynorod bloke says that it's a wonder it didn't block sooner as all the solid waste would trap in that small black horizontal lower pipe. He reckoned that the pipe was a smaller diameter than the white pipe by 2-4 mmm
Anways, thank you for taking the time to read this much appreciated and, thanks in advance for any feedback. đź‘Ť
Monty
Hi Monty, The installation is a nightmare it is wrong in so many ways. On a temporary basis you might undo the big nuts ..with a washing up bowl underneath, take the traps outside
clean out with water from an outside hose and re assemble.
Ultimately the arrangement you show will need
re building inc. a lower outflow to the outside. To be honest this is not beyond a decent Diy person and if you are unsure you can come back to us for help ...............centralheatking
it looks a bit like that screensaver from years ago which built up a bonkers pipe network
The pipe doesn't stay in the trap because the seal has come of the pipe and pushed into the bottom of the socket.
Or it was never fitted, but I think you'd have had leaks if that was the case.
Depending on what is behind the back panel it shouldn't take someone with experience too much trouble to sort it.
Thanks snowhead/centralheatking/scott_d đź‘Ť much appreciated
[automerge]1571065347[/automerge]
update: been to the company that installed it and they've agreed it's a bodge and will remedy it FOC so thanks for all your help guys đź‘Ť
Reply to Had an new bathroom fitted - sink blocked, called dynorod out, he laughed, HELP! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping for some advice on the use of AAVs while plumbing in my new bathroom. There is a sketch of the waste layout in the link below. All of the...
2K
Stephen44uk
Hi everyone, I have an issue with my bathroom sink. It's been "blocking" regularly, maybe once a month, for at least 3 years. The sink fills with...
3K
Hi everyone, First a quick bit of background : I'm English, living in France, and renovating a 1960s house, which has pretty much needed to be...
2K
Bit of wierd one but here goes. Live in a Tyneside flat (Think Terraced house split in two). With a modernish kitchen and bathroom extension into...
  • Locked
Good morning, I found your forum via Google after searching for some plumbing advice. We have recently installed a new sink however struggled...
