Discuss Heatline Vizo 24, no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
Evening all,
Been to this vizo tonight and no hot water.. but heating works. There’s no fault light on the display neither. When you run the hot tap, nothing happens. The little port above the Hall effect sensor that houses the wet end of the pressure gauge has been weeping out onto the three wire sensor cable and nearly corroded off the pins. Could I take it that the sensor and cable are goosed?
It doesn’t help that Heatline have absolutely dire tech support to determine the fault.
yep sounds like its not reg the flow
Reply to Heatline Vizo 24, no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
