Discuss heatline vizo no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
doogiee
hi heatline vizo no hot water in water only mode, boiler is up stairs but when i turn on the central heating i get hot water in the kitchen down stairs but intermittent warmish in the bathroom up stairs
There's an issue with your boiler by the sounds of it, best call a Gas Safe Registered engineer to look at it or pop up an advert in the appropriate sub forum.
Reply to heatline vizo no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
