Discuss [HELP] Impossible to remove toilet seat cover in the USA area at PlumbersForums.net
I have a toilet seat that is impossible to remove. I've never encountered anything like it before.
It's a single piece design, so accessing the underside is very difficult (out of sight, with maybe 4in between the wall and the water closet). Took a picture with my phone camera - and there doesnt appear to be a nut on the underside either
The top piece is chromed marine brass. This thing doesnt dent. I've taken out all the screws and it still wont budge. Loosened all the hex nuts (for tightening the soft close mechanism) and it still wont budge.
I cant seem to take it out.
WA332/SB3320
The chrome fittings dont have anything that can be removed to expose the screw.
The nut is captive within that black bush (which appears to be cracked).
Looking at the shape of the hinge it looks like the top section will slide towards you , revealing the screw below....
Looking at the shape of the hinge it looks like the top section will slide towards you , revealing the screw below.***
what do you mean by 'top section will slide towards you'?
I've tried pushing it to all directions. it does slide a bit, but nothing comes out.
Ben gee is saying and I agree that the part left on the pan separates.
The screws in the side lock the top to the base.
It's probably stuck with remnants of the waste that should have gone down the pan. 😳
Try pouring hot water over the chrome part then slide it off
Looks like it's got sealer of some sort under it stopping it form moving
Reply to [HELP] Impossible to remove toilet seat cover in the USA area at PlumbersForums.net
Hi folks, sorry to have to post this but we got a new bathroom a few months ago and the toilet seat was loose at one side. The cistern is...
1K
Can anyone tell me how to remove this top fix toilet seat? I've tried squeezing both fixings from the inside but there's no movement.
1K
Hi all, I recently bought one of those under the seat bidet sprayers for my toilet, but cannot for the life of me work out how to get the seat off...
10K
Hello I cannot get my toilet seat to tighten. I have no access to underneath the toilet. I have taken the toilet seat off and tightened the...
5K
Hi there. So i need to change the Hatria toilet seat cover, but i cannot take it off the toilet so easy. I found few hidden screws in the hinges...
3K
