Discuss Help wiring up a Drayton digistat scr unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
w-dc97
Help!!!!!!!!!!Can anyone advise me how to wire up a Drayton SCR unit. There is a live/neutral/earth from the mains and from the boiler a red/blue/earth & a yellow!!! cable. I've no idea what goes where. Can anyone tell me what wire goes in which hole, please.
I wire then from the feed into the receiver. Live in L neutral in N and earth to earth. I then take my live neutral and earth for the boiler from the same l,n and e on the backplate. For the switch I believe it's 1 and 3 on the backplate to your 2 connections on the boiler.
oh dear. do you know what they were connected to on the previous programmer? If you don't need to look at the connections inside the boiler, which your not allowed to do unless gas safe.
if you had to make a guess how would you wire it up with those four cables?
Reply to Help wiring up a Drayton digistat scr unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
