Discuss Help with Gazco studio 2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Alexis
hi I hope you can help. We have recently had a gazco studio 2 open fronted fire fitted.we also bought the granite inserts. However the flames are not 'straight' - they lean to the back of the fire. This means the granite is being burned and black carbon deposits are being left. What could be causing this? Thanks in advance. A.
You need to urgently get the gas engineer who fitted your fire back, and till then do not use it
Standard on the Gazco fires unfortunately if in doubt contact Gazco on
01392 261950.
The other thing to do is switch the fire on and turn it to low straight away for 10/15mins to allow the granite to heat up slowly stops it cracking
Reply to Help with Gazco studio 2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, recently our boiler stopped working properly, causing a lack of heat in our 14-radiator splitter in 3 storeys. having only one boiler at...
Hey all Looking for a consensus on an issue that has arisen. Disclaimer is that my ideal icos 12 boiler Is over 10 years old but has been...
2K
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
Hi everyone, I'm looking for some advice please. My system has 5 Drayton Wiser TRVs. There are 8 rads over 3 storeys and a 170l unvented...
2K
