Discuss Help with leaking connector pipe under bath in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I've got a leak at the connector next to the p trap under my bath at point 1. on my attached photo.
I unscrewed it and pipe A hardly goes into pipe B - it's almost flush with the start of B. Assume the rubber seal (can't spell) has failed - there's not much chance of water passing through without leaking.
Can I use a female connector to sort this out? Or just a new thingy that you turn? Or what's best interim solution till I get plumber out next week. Two young kids so need showers at some point. I'll keep the tupperware there incase. Just had fresh plaster skimmed downstairs and this has leaked onto it.
Any tips greatly received. Thanks and have a great bank holiday weekend.
Yep as above
Undo the nut slide to the right next you should have a plastic washer (you might not depending on the trap) then you should have a rubber coned washer on the pipe I suspect it’s in the trap where the pipe goes get a small screwdriver and fish it out and install it on the pipe cone facing the trap and push the tube into the trap and slide the nut and tighten all up
Reply to Help with leaking connector pipe under bath in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
C
I live in an ex local authority end terrace house. I am unsure if I have an underground leak from a water pipe? Scottish Water tell me they can't...
Me again. This turning out to be a nightmare from hell this bathroom. Your help do far has been invaluable. So, the next issue is one that I may...
A
Hi there, I recently purchased a flat that was built in 2016. The apartment is still under the NHBC 10yr warranty. Since moving in, I discovered...
Amelia
A
