Rob Foster
- Messages
- 2,083
Centralheatking
Discuss Here us why cheap pan connectors eventually leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
HOW MUCH! Is that including all taxes and next day delivery?You can chose different pan connectors which are not cheap Geberit 241.525.00.1 PE-Anschlussbogen 90° für Wand-WC ausziehbar Drm. 110/90
Including vat but 5.99 for postageHOW MUCH! Is that including all taxes and next day delivery?
You don’t need thatAnd import duty?
Whats wrong with a brown connector, it is the same ID does not leak and was in the back of one of the vans ?I'd be more concerned about, what appears to be, an underground drainage fitting that the pan connector is connected to, or is that temporary too?
Cranberry Sauce with my chicken roast dinner yum yumRob been on the sauce again?
The plastic used for underground fittings & pipe does not have the same chemical make up as the above ground fittings & pipe, it does not have the same level of protection against the elements, especially UV protection from the sun. It breaks down much quicker than above ground drainage fittings, this is why it is much cheaper, and should not be used for above ground. Mind you, I suppose if the fitting in question will be cemented into the wall, it might be okay, but I for one, would certainly not recommend it.Whats wrong with a brown connector, it is the same ID does not leak and was in the back of one of the vans ?
centralheatking
Reply to Here us why cheap pan connectors eventually leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
