Discuss hot water flow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pauls
got toa call today no hot water got it running out slowly then sometimes slows down checked tank in loft full and drains when taps run.
any ideas on how to cure cos i think im missing something.:confused:
Stick hosepipe from cold onto hot tap and turn on - should blow airlock out but be careful not to overflow the header tank!
If it's a recurring problem, fit an automatic air valve to the locked section.
its only just started out of the blue they had some work done back in january
See what pipework has been altered and use a spirit level to check the falls.
check the tap washers I don't remember the details but had a job that was getting air and it was from a bad bath tap
cheers fellas for help.
the system also has other issues with need attention aswell
like no cylinder stat.
no interlock controls couldnt find them anyway they could be under floorboards but what a stupid place to put them.
when i opened the airing cuboard i touched the cylinder and it was red hot its a safety issue and needs sorting.
with no interlock controls heating and hot water on all the time
force the mains through the hot tap at kitchen sink clear air lock
Reply to hot water flow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys, I've got a woodburning stove with a back boiler that I cant quite figure out. Last year it was heating the water but not the radiators...
1K
I'm after some guidance if possible please. I have a fortic F1 vented direct cylinder with an instant immersion and an economy 7 immersion. A...
DevishaM
Hi I have a gravity-fed system I have flushed it out a couple of times and it has had x400 in the system for the last 4 weeks. There was one...
1K
Hi, I've got a leak coming from the loft into a bedroom which I think is caused by water overflow from feed and expansion cistern (see attached...
2K
Hello. Decided to clean sediment from my cold water storage tank(just sediment nothing else is there). The pipe to the tank also splits off and...
3K
