Discuss How do I reduce from 12mm to 8mm without using several joints. in the DIY Plumbing Forum area at PlumbersForums.net
Paul Alone
I'm building a steam punk clock and am using a thermometer pressure gauge as one of the parts. What I need to know is how can I plumb to the rod extending from the pressure gauge without using several parts. The rod diameter is 12mm and I will be using 8mm copper piping for the project throughout. I have tried everywhere for a reducer but no one does one in the size that I need. Would the only alternative be to fit a 15mm to 8mm reducer which is freely available? If so what could I use to pack out the extra space?
Option 1
Option 2
Required for option 2 BES.co.uk | Next Day Delivery On 15,000 + Plumbing Supplies - https://www.bes.co.uk/end-feed-straight-coupling-12mm-f-x-f-6767/
Thanks for the help guys it seems the luck of the draw having someone who is based nearby. I was all over ebay, B&Q, screwfix and wickes and no one had what I needed. Think I can manage now.
Reply to How do I reduce from 12mm to 8mm without using several joints. in the DIY Plumbing Forum area at PlumbersForums.net
