Discuss How to drain heatline boiler Monza 24. in the USA area at PlumbersForums.net
Hi I need to replace the pressure gauge on the boiler and needed some help on how to drain/isolate the water in the boiler first.
Help would be greatly appreciated!
Thank you.
isolate flow and return and incoming cold under boiler, under boiler there is a drain off, may look like a black bit sticking down back rh corner with slot in it for flat head screw driver, open slowly have bucket ready, fully drain, when you disconnect your presure pipi they may be a bit of water, refit new p. pipe, tighten drain, open all taps under boiler, re fill,
hope that helps.
Reply to How to drain heatline boiler Monza 24. in the USA area at PlumbersForums.net
Hello, would greatly appreciate some pointers Toilet downstairs drains slowly. First floor toilet causes bath to reflux water and make noise...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Greetings. I have an external Worcester Bosch Heatslave boiler and have a question about pressure. The boiler pressure was set to 1.5 during a...
