Discuss How to open up toilet waste pipe please in the DIY Plumbing Forum area at PlumbersForums.net
How to open this toilet pipe please?
I need to retrieve a key I dropped down here.
I think its sitting in the grooves of the flexible pipe.
Will this pipe unscrew easily, I can probably untwist it OK.
But then after is it easy to reconnect and ensure its water tight?
Any advice gratefully received.
Many thanks
V
Should just pull of the toilet if you have enough space if not the toilet will have to come out
You''ll need to separate A from B.
There will need to be a small gap where the green arrow is.
If there isn't enough room to move A all the way back, you should be able to twist it up or down to release it.
If not, as ,the toilet pan will have to come out.
Reply to How to open up toilet waste pipe please in the DIY Plumbing Forum area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
