Discuss I have a leak from a monobloc tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The tap is a Dakota supplied by PlumbworldProbably an oring issue if from the base of the spout. What tap is it. Can we have a picture please?
Is it definitely not running down the tap anywhere?It appears to be leaking from the base of the tap where the flexible tails go inside the tap . If the “o” ring was damaged why does it only leak when the tap is turned on?
Reply to I have a leak from a monobloc tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
