Discuss Incoming water main hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It just shows you how things can go wrong without us knowing, if the water hadnt heated prompting the call out that couldve really bad, well done mate,
Thanks for feedback , Many accidents are preventable with hind sight.
( Currently enjoying warm fuzzy feel ,without buzzing tingle as slide hand across bare metal )
Sounds to me tap at kitchen sink is mixing! Try non return valve on hot supply to the sink cheap and easy!
Reply to Incoming water main hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the...
Mike Young
M
A
Hi, I am replacing a kitchen tap and have run into some trouble when connecting the flexi hot and cold pipes to the hot and cold mains pipes. The...
Adam tl
A
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
