Discuss Increasing gpm/ compensating for low pressure in the USA area at PlumbersForums.net
I came across this image @ Pipe Diameter Affects Water Flow Small changes in pipe diameter make a big difference - https://inspectapedia.com/plumbing/Larger-Water-Pipes-Effect-on-Flow.php
I'm working on a house where I reckon the mains pressure won't be great. It's at 1.8 bar static. Its a half inch pipe feeding two tanks, kitchen sink and three outdoor taps. There's a water softener which will cause a drop of 1 bar.
I don't think the remaining .8 bar will be good enough as the main tanks has some constraints. It's going to be behind a wall on the second floor which restricts it's size, and it has to feed one hell of a power shower.
Would it make sense to follow this article and try to increase the flow rate. I can go from the half inch hydrodare to 3/4". I know it'll do nothing for the pressure but could the extra flow rate help feed the outlets?
You will increase flow but loose some pressure
Reply to Increasing gpm/ compensating for low pressure in the USA area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
