Discuss intergas OV boiler convert to outside temp compensated in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
i currently have an intergas boiler on an OV S plan setup. i want to add the intergas outside air temp sensor and cylinder temp sensor and then wire to suit the current 2 valve setup. any wiring plans or guides please.
Enough info in instructions and online.
The wire for the outside sensor can have a wall switch in it (light switch). It then turns on weather compensation or it will run as normal to the set max boiler temp.
Reply to intergas OV boiler convert to outside temp compensated in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
