Discuss Is this a pan connector? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Silly question but almost looks like a soil bend fitting to me, plus it's green.
I need to change the pan connector.
Looks like it goes into some other fitting which is inside the soil. What bits best to use if you please, plumbchums?
Yes and the green but is a collar of the pipe either cast or clay (you might need to remove this)
Sorry remove which bit? The bit inside the collar that the pan connector goes into? What is that/doing? I've put pan connectors straight into cast iron soil before and not used anything else so not sure what the inner collar is or what it's doing..
The outer collar will still work if you left it there just no point and luck ugly
The inner collar bit could be a drain connector
McAlpine DC1-BL drain connector 110mm Black | Plumb Center
And then a stnd pan connector into that
What's the point of that then? As opposed to just putting pan connector into soil?
It's all academic now anyway as the sod cancelled the job.
As it's cast is could be slightly bigger so the pan connector would be a bit loose
Some times a pan connector fits fine but others is too big or too small to accept one
Reply to Is this a pan connector? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
