Discuss Is this cylinder vented or unvented? in the USA area at PlumbersForums.net
so does that come under vented or unvented? Sorry for dumb questions.Looks like a thermal store
The portion at the top replaces the loft tank
No longer available I have fitted a few of these in the past and the heating side is vented .kopIt's vented bud a Range Flowmax combination cylinder. Kop
They are no longer available bud but there is a replacement and apparently G3 is not required I would of said it was but Manufacturers instructions say no so there's your answer bud nice bit of scrap when you strip em outSo KOP its vented heating water and mains pressure hot water, is G3 still required on one of these? Being mains HW I assume yes
Replace it with an Unvented cylinder and upgrade the system. Never been a fan of thermal stores.Are these cylinders any good or should I be thinking of replacing at some point?
It's not a combination cylinder then is it, it's a thermal store. Even your screenshot says that.It's vented bud a Range Flowmax combination cylinder. Kop
Replacing with vented cylinder: Wouldn’t that mean having to have a tank in the loft?Replace it with an Unvented cylinder and upgrade the system. Never been a fan of thermal stores.
[automerge]1585436171[/automerge]
A traditional combination cylinder is a HW cylinder with an integrated tank above. A thermal store is a tank that stores water whether that be a vented system like the one shown or a sealed one.
Mr Evil said unvented David this virus chaos is having its effect on us all we are a touchy, sit tight keep what you have the problem I find with them is in the summer the unit is always hot to be able to produce the hot water supply as it's not stored . Regards kopReplacing with vented cylinder: Wouldn’t that mean having to have a tank in the loft?
Yes it's a thermal store bud and your description of one above is correct . Keep well budReplace it with an Unvented cylinder and upgrade the system. Never been a fan of thermal stores.
You'll struggle to get Evohome to work correctly with a Thermal Store - the store has to be Hot to supply heating. The HW control on the EvoHome isn't suitable for what you require, the HW kit on the Evohome is for stored HW, which you haven't got (basically you system works in reverse to a normal HW cylinder. The store is Hot and the cold water goes round a coil in the cylinder to heat).Thanks for all the advice - much appreciated. I'm planning to add Evohome TVR'S / controls to my very basic system to give more controllability! So I'm trying to get my head around what I'm going to need. If it's vented I need one type of Evohome fitting and for unvented a different sort. I don't want to change the cylinder unless there's no alternative.
Thanks again for help!! Keep safe.
Yes but you'd have to leave the 'HW' on the clock permanently on and just use the Evohome to control the Heating side.Damn and blast !!! Could I still use the Evohome to control the rads?
What would be the simplest and cheapest way of upgrading my existing system? Worcester Condensing boiler in utility, thermal store cylinder on landing?Have to agree with Evil the set up you have is not really suitable for Evohome I would advise upgrading to unvented when possible. Kop
yes, here's a photo of my controller.Yes but you'd have to leave the 'HW' on the clock permanently on and just use the Evohome to control the Heating side.
As I take it as it stands, you have to have the HW on with the CH on?
Any pictures of the boiler if it's as old as the controls then you may consider a full upgrade ? . KopWhat would be the simplest and cheapest way of upgrading my existing system? Worcester Condensing boiler in utility, thermal store cylinder on landing?
[automerge]1585567506[/automerge]
Reply to Is this cylinder vented or unvented? in the USA area at PlumbersForums.net
