Currently reading:
JG speed 22 to 15 reducer for compression?
Discuss JG speed 22 to 15 reducer for compression? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gungaabayar
Hi All,
trying to put 22mm auto bypass valve (compression fit) into 15 mm pipe system (in very tight place)
Can I use JGSpeedfit 22 to 15 reducer as shown on the photo, and is it safe enough?
Olive and 22mm plastic end are little loose,
obviously it makes my job much easier if I can use it?
cheers
Hi All,
Can I use JGSpeed 22 to 15 reducer as shown on the photo, and is it safe enough?
obviously it would be much easier if I can use it?
cheers
Good morning,
me personally I wouldn't recommend push fit just because of my experience. I just like more rigid stuffs solder etc. I do not know how good it will seal and for how long for therefore I attend using different materials
but do not over tighten the nut as its plastic.
as snoopy8888 said it will be fine, if you want you can tighten it up to compress the olive then loosen off and wrap some ptfe tape round the olive for peace of mind.
Hi
how can I shorten this connection which goes to 15mm pipes (without any pushfits)?
impossible to soldering both end of the 15mm end, but can do soldering on 22 pipe side,
is there any reducer or coupler (dnt know exact name) which is like one end is 15mm compression and other end is just plain 22MM pipe which can be used for compression fitting.
This is from MI
Usual working Maximum working Maximum working
temperature ºC temperature ºC pressure, bar
Cold Water 20 20 12
(indirect and direct mains
Central Heating 82 105 short term 3
malfunction at 114
Hot Water 65 95 6
(including unvented cylinders)
Bump. Bump. Bump
Steve.
I'm interested to know myself.
I think gungaabayer would also like to know.
From memory this was last weekends DIY project.
Or was that another project????
It's a 3 part fitting, a brass bush which goes into the 22mm comp fitting, an olive, then a shorter brass bush which the comp nut tightens up against, which inturn, compresses the olive like a normal comp fitting
If I haven't explained well enough, as soon as you see the fitting it will make sense
There's a single part fitting that collapses onto the pipe when you tighten up the compression fitting here:
Reducing Set 22 - 15mm | Compression Reducing | NoLinkingToThis
Just need the usual 22mm olive; 15mm pipe into 22mm fitting.
If space is really tight then could also use a slip coupling Compression Repair Fitting 15 x 100mm | Compression Sundries | NoLinkingToThis
That way you can put one part in then slid it along.
Hi again
because of lack of space can I connect the Auto bypass valve in this way in which so much bend involved? have a look the drawing attached,
all this bends affect the valve as well as whole system or not?
(might be stupid idea)
cheers
Hi again
cheers
Needs a bit more of a re pipe to avoid un necessary bends as others have said i would get someone in and save your self the trouble and headache
Hi all again
things went not too bad,
bought compression internal reducer from wicks ([DLMURL="http://www.wickes.co.uk/Wickes-Compression-Internal-Reducer-22-x-15mm/p/420222"]Wickes Compression Internal Reducer 22 x 15mm | Wickes.co.uk[/DLMURL]) it works very easy. no need reducing coupler. The fitting may look awkward but the ABV worked like a charm.
just wondering do I need to mount this odd fitting into the wall to play safe? or is it ok?
thanks guys everybody who helped me through this forum
many thanks
Good grief! Was there no movement in the existing pipes?
You could have used an angled bypass valve, though it still would have needed copper bent
Dont feel anymovent,
Tried to put angled bypass valve but the adjustment head needed to go other way around or upside down, so sticked with straight one.
Reply to JG speed 22 to 15 reducer for compression? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
