Discuss jumpers electrical ground or what? in the USA area at PlumbersForums.net
ok is it electrical ground or dielectic. I will remove then replace when done, should I shut off electrical breakers or is it necessary? Should I place it in a different spot or can I remove it for 3 hours or so then replace?
Reply to jumpers electrical ground or what? in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
We are from Alberta, and I own an electrical company.
I have been asked by a BC Mechanical P. Eng. to install an emergency STOP button at the...
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
