Discuss Lagging cutter. New invention in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Chalked ...Will make a neat job I've seen some of your install pictures so will be the bees knees......how much out of curiosity if you don't mind me asking.....regards Turnpin:)
seen and already got one very good needs some mods tho
What size does it take ? Think the clamping method needs looking at could take some time to make joints, Think I will wait for the Mk2 model !
15x19mm all the way upto 28mm thick
It is actually ok. Watched it in person. Definitely would take a bit of practice to get used to though. The clamp doesn’t have to be tight. It is more about the blade being sharp so you get a clean cut. The clamp is just a guide to run the blade down
It looks good, hopefully as easy to use as the video.
The guys on site just use a bread knife
Bread knife lubricated with water! Remember, the grey (polyethelene) is easier to cut than the black (nitrile). Never zip tie as you seriously reduce effectiveness if its compressed. Clip or tape the grey, glue the black....
Leaves a very neat professional job I'm quite impressed. It comes with a toothless saw which will probably get lost in the van but it makes a brilliant looking cut.
The saws an extra
I just ordered the jig. Couldn't justify the cost of the saw. May well buy at a later date if required. Did any1 see the siphon sucker the same bloke designed?
I did wasn't impressed esp at the price under a tenner would of given it a punt
And in my opinion I don't like the saw it's too big I would recommend a knife
I've already modified it :D
Top pic is 28x9mm
Bottom is 22x9mm
If people would like a review will sort something out
Fyi the saw is rubbish
I use a company for some pipework that we do but thats for refrigeration. Heating pipework should be the same imho but generally not
Mine came today. Thought the saw was good.
Works well , but could be made to adjust easier.
Ordered the same! Yet to try, but have a cylinder cup just finished so lagging that in 13mm.
I guess you could just cut the lugs down slightly that the bolts go through.
I bought the syphon sucker aswell so well see!
Find it too big (the saw)
:D that's what I did too both of the raised internal nubs off
Reply to Lagging cutter. New invention in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
