Discuss Lead pipe from toilet to soil pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
easyt
I was surprised when I replaced the toilet just over a week ago. The exit pipe to the soil stack was in lead? The house was built in 1964. Was this common?
I would have though this matrial would have been phased out earlier than this.
EasyT
Hi. There were still a few about using this method / material. By using lead pipe through the wall and on to the pan is gave a certain amount of flexibility, that reduced stress on pan china ware and easier to adjust to suit pan connection. A brass caulking bush was wiped on to the lead pipe, before entering cast iron branch on stack.
Reply to Lead pipe from toilet to soil pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
