Discuss Leaking joint on Aluminium radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SMB
Where the valves screw into the aluminium rads has started to leak (all be it not that much). The system is a ordinary pressurised sealed system. The leak is hardly enough to drop the pressure. The system has been fine for 4yr+, I guess that the rubber gasket has started to fail. I have tightened the joint a bit, seemed to work for 6 months.
Obviously (rad) the system needs to drained down and the joint sealed. What is the best sealer to use on the treads?
1. Be careful, many aluminium radiators have left hand threads on one end, usually the right hand side. It's to make sure tightening up the tail nuts doesn't unscrew the connectors between sections.
2. The best seal would be cleaning the mating surfaces and replacing the rubber rings (normally "O" rings) with new ones.
3. If new seals aren't practical, I'd use Loctite 55. You'd need to rough up the male threads gently with a file.
4. If you can find the make / model of the radiator you can probably find the installation instructions on-line.
Do you mean the leak is at the threaded chrome "tail" that joins the valve to the radiator end caps or are the end caps themselves leaking where the caps screw in to the rad?
Thanks for your reply.
The leak is between the end cap and the radiator, not the chrome tails.
If I replace the o ring, what type of rubber should it be made of.
To be honest I don't know what type of rubber they are made from (also some brands of rad use a flat fibre washer instead). If you go to a plumbers merchant and ask about aluminium radiator bushings and seals they may be able to supply them.
I'll admit that when I don't have any to hand I build up a washer/gasket with PTFE tape, not on the threads themselves but build up a seal by putting a load of wraps of tape at the flange and I've never had a problem with them leaking.
Reply to Leaking joint on Aluminium radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
I've got a leak at the connector next to the p trap under my bath at point 1. on my attached photo. I unscrewed it and pipe A hardly goes into...
Hi, This part of my radiator has recently started dripping, tried a new washer and ptfe tape on the thread but I think it’s coming from where that...
I have just tried to balance my heating system (16 cast iron rads, 3 towel rails), all the lockshields were fully open. When I try to close them...
K
My Worcester boiler is losing pressure. It only happens after the boiler has been on and it loses approx 0.5 bar each time. The expansion vessel...
