Discuss Leaking Soil Stack ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've attached a picture below of a leaking PVC soil stack that needs to be repaired. As can be seen, the leak is coming from the bottom of the stack from what
appears to be a socket ! My first inclination was to cut a small section ( about 3 inches) out of the stack about two feet up from the leak and then pull the
lower part of the stack out in order to see the best way of making the repair.
There is a horizontal branch (for a toilet) about 8 feet up from the ground that goes directly into the house so this should support the upper part of the stack
while the repair is done. However, once the repair is made, a slip coupling would have to be placed over the cut segment of pipe but this would then obviously
not give any support to the upper half of the stack !
Removing the stack completely to make the repair would be a nightmare because of the horizontal branch going back directly into the wall for the WC.
Any advice would be appreciated.
Thank you.
Would be easier as a two man job, one to loosen and lift the top half of the stack, and one to slip in the new section of pipe. You may have to lift the top half of the stack up, pull the tee off the horizontal branch then start from the bottom again.
Sent from my iPad using Tapatalk HD
Thanks for the response TBServices.
The tee is turned back directly to the wall and the branch is cemented straight into the wall. If the top of the stack was lifted up out of the tee there would still be no way of removing
the bottom part of the stack from the tee as the tee is fixed directly into the wall with no movement available.
Thanks again.
Oh I see! Well in that case it seems you're out of luck. Short of taking it all down I can't see another way of doing it right. Maybe someone else will have an idea
Bashing out a bit of concrete and making good on the outside won't be too much of a problem if you need to remove WC branch too. It's all down to how much of a headache it is to get it back to looking ok inside and how round the houses it goes from WC to stack.
have you checked its not blocked seem like a lot of leakage i assume the water is coming out of the floor ? before cutting the stack id check for blocage and then cut back round the base see whats there chances are it just needs a cement fillet replacing round the drain
www.ebay.co.uk/itm/...Rubber-Coupling...Soil...Pipe...-/4001728548...
you could cut the stack then use a rubber fitting, don't look much but give more flexibility
Re: jjjjjzzzz
Thank you for all the posts.
Can you put a clip directly below the branch to support it
Yes I could do but there would be sufficient support from the tee branch that goes directly into the wall to not make this necessary.
I must admit I hadn't considered a blockage. The leakage is coming out from around the seal below the end of the socket just above the ground level.
This link doesn't seem to working but, at a guess, is it rubber slip coupling with jubilee clips at each end ?
thats interesting my friend, good
What does this refer too ?
Thanks again.
I would say that if that brown stuff is .... I would lift a manhole to eliminate a blockage first before you cut into . IMHO
It was a quick visit but, despite how the picture looks, I certainly don't recall it being "brown stuff".
However, I'll now certainly be lifting a manhole cover before I even consider cutting into the stack !
Ok, I know this was over a year ago but the customer was supposed to come back to me and they never did.................... until now. Things are still the same and the job now needs to be done.
I can confirm that there are no blockages. The bottom fitting is a plastic double push fit coupling from standard black soil pipe to a larger underground plastic. The reason why it's leaking is that the rubber seal in the double coupling connecting on the red/orange underground pipe side has literally dropped out of the coupling. To me, this implies that the seal was pushed out when the stack was first installed as it wouldn't just fall out of its own accord. Additionally, there is a leak from an access panel so higher up so two leaks all together. The stack cannot be lifted as there is a right angle branch going directly into the wall approx 2.5m above the leaks for a toilet on the second floor.
I have tried to find a similar push fit plastic coupling the same as the one in the picture but all I can find is a rubber coupling. The only way I can see doing the job is to cut about 6cm out of the pipe above the access panel and lift out the remaining soil pipe and coupling. Install a new coupler (plastic if I can find one, rubber if not) plus a new piece of pipe (with inline access panel if I can find one) and then a rubber slip coupling.
I'd welcome any other alternative idea's or advice please.
Thank you
Horrible jobs these ones.
Access covers such like this one is now on a tee (believe i got them by osma)
I think the best option would be to put a slip coupling on and fresh pipe, its obviously damaged the rubbers since normally 4" rubbers dont really give any problems..
Thanks for the post Koogatubac.
I was intending to cut the pipe out just above the access cover and install a new coupling, piece of pipe (without access) and slip coupling where the cut had been made. However, I can't find a coupling the same as the leaking coupling (with blown seal) as I'll be taking out as they all seem to be rubber nowadays !
Thanks again.
Sorry to be bearer of bad news lol its the silver fittings with the 2 jubilee clips each side that fits right, also you can use a pan connector that will slip inside the cast/clay if thats better?
Its all a sightly job in the end. Best job but pricey would be to renew the stack
I think if t was me i would be knocking out the cemented tee and remove the upper part of the stack 1st and then replace the damaged coupling and re-build and make right. Just charge accordingly. You want to get it right 1st time while the cust is paying not have to come back and do it again for free.
Thanks for the pic smtplumbing. I've seen plenty of those fittings in the merchants but had hoped to get a solid plastic fitting like the one that is installed already. Either way, I'd have to cut a piece out of the pipe and also use a slip coupling. Apparently, the stack was installed by the council but, as far as I'm aware, the tenants now own the property but they can't afford to have the whole stack removed in order to replace the leaking joint. To be honest, the jobs a pain in the a**e and, after more than a year of not hearing anything from the customer, I'd assumed they'd got someone else to do it. I'm inclined to think that everybody else was suddenly very busy after they'd seen the job.
if you have a branch cemented in the wall the stack wont fall down dont cut to close i cut a metre high and replace from there down get a new section in using a 4 inch slip coupling or a fernco rubber then cement the base if you cant get a 4 inch slip coupling ,change merchants or rasp the stop out of a normal one
Steve, found a solid (not rubber) slip coupling in Wickes of all paces.
You need to be looking in builders merchants for the underground to above connector;
The link is for Supersleeve pipe, depending on it's age it may be older Hepsleeve which had a slightly larger diameter.
Hepworth Supersleve Housedrain 100 Adaptor Coupling To Hepsleve
That looks perfect snowhead, thank you.
Reply to Leaking Soil Stack ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
