Discuss Look how this pipe has been snapped.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
djob
Went to do some work on this pipe & it just came away in my hand.. I thought it was a bit strange how clean of a snap it was.
Had it already been cut part way through with cutters? I had one a while back on a boiler change someone had started cutting it then changed there minds. Good job it was drained down.
Didn't think about that, seems like th answer..
If you do 1 complete turn on the cutter then put the pipe in a bender and bend on that cut it will snap! It makes a big difference!
Reply to Look how this pipe has been snapped.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
I'm putting a new yorkshire fitting on the end of a pipe from which an old fitting has been removed. Do I need to remove all traces of old solder...
Hi all We noticed water suddenly backing up through the pipe for the dishwasher drainage pipe yesterday - first time this has happened. When I...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
