Discuss Looking to see what iron pipe part can fit a 10mm ball joint? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Looking to see what iron pipe part can fit a 10mm ball joint? In this pic there is a part that connects the ball joint (or whatever they are called) to the 1/2 inch pipe. I am looking to connect to a 3/4 inch pipe. Are there any threads that do this? Thanks
I have been told that in North America these would be 1/8 threads. I guess they use imperial size threads and we use metric. I also hear they use NPT not BSP :(
Looks like 1/4 inch, 3/8 is around 15mm dia
I've been told it
I've been told it's probably 1/8 NPT. I understand this isn't compatible with BSP. Our lamp ball joints are 10mm. As such this is getting too complex and I will have to give up. I appreciate your help. I can't see any other way of doing what is in the pic but 10mm to 3/4 inch bsp.
1/8th is around 9.8mm dia
If it’s a one off and you can’t find anything, it’s not too difficult to turn something out of brass on a lathe. Pay a local craftsmen if you don’t have the skills.
Or consider buying something the wrong size but quite close that you could re-tap to what you need.
This is really helpful. Very. I'll look into it.
Reply to Looking to see what iron pipe part can fit a 10mm ball joint? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
