Discuss Loose 'RAK Ella' toilet seat in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi - Not quite sure how this forum works so this query is intended for all members - I have attached photos of a 'RAK Ella' soft close toilet seat with hidden fittings which was bought and fitted about 5 years ago. The seat has started to become loose and I am not sure how to tighten it. I assume that there are 2 grub screws that need to be loosened with a small allen key, after which you pull up the whole seating unit to remove it. This would then give access to the hex nuts for tightening with a spanner. After tightening, assume you just push the seating unit back in and tighten the grub screws to hold in position.
I would appreciate if anyone could confirm that this is the correct way to do it or advise me differently.
Reply to Loose 'RAK Ella' toilet seat in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
