Discuss Magnacleanse Power flush filter versus pumped machine in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Smeagal
Hi everyone
I am just on the verge of buying a Fernox powerflush pump,but am quite impressed by the Adey Solutions magnacleanse power flush filter and its claim of doing a six rad flush in two hours.anybody used one? is it as good as they say,at a third of the price of a fernox powerflush unit and a faster clean timeyou would think it would be a no brainer but cannot do heavilly sludged systems.I would be interested to hear what the forum thiinks of them.Thanks for your thoughts.
Smeagal
Its the Mutts Nutts and will strip out all magnetic sludge and the water you dump is always clean..worth its weight in copper!!!
Hi Spudhater
Have you used one? I think they have just come out beginning of the month how do you find it does it reduce flushing time, it would be interesting to know.
Smeagal
Bro in law has one,he has a Norstrom Power flush (with heater) when used with the Magna clean (which has been around for a while) you do not need to keep dumping the dirty water so it saves quite a lot of time.
He reckons it is the best bit of kit he has brought!!!
Bro reckons it`s the best bit of kit he has brought
hi Spudhater
Thanks for the info very helpfull but Adey have just brought out a flushing machine called Magnacleanse which its sole purpose in life is to provide a flush and is supposed to be quicker than a Pump type system anybody else seen this advertised comments would be helpfull thanks!
Smeagal
it is the same kit as my bro -in -law uses on his pumped machine..
They are marketing it as a stand alone cleaner, good idea in my view, i spoke to the rep at the Phex show and he said this is all you will need to clean all the "MAGNETIC" sludge..
I use one with a fernox power flushing unit and would recommend but can't see it can be used on its own
eco
Thats what I think according to the Adey literature it can act as a stand alone unit utilizing the ch pump,but is that going to provide enough velocity to shift the magnetite sludge ,they seem to give the impression this thing is going to put Pump based units in the museum!it may have been better combined into a pumped unit.
Reply to Magnacleanse Power flush filter versus pumped machine in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
  • Locked
Powerflushed a system today for a new combi to go in, coming out was an old open vented pumped central heating system with a multipoint for the...
7K
  • Locked
Hi all, Got a problem where only a couple of rads getting hot in bungalow. Originally it was the bed rad stone cold. Drained and flushed the...
2K
sparky
  • Locked
My mum is in her 80's, if she knows a tradesman then she would trust them and if they recommended something then she would assume they were right...
3K
G
  • Locked
My plummer is fitting a new Worcester Greenstar 37cdi in my house. I have 11 rads, 8 old ones and 3 new ones. My plummer is recommending a power...
4K
migoplumber
M
X
  • Locked
I just cleaned out my DHW heat exchanger to fix a reduced flow problem in the hot water (all nice and hot-hot now). The amount of oxides (no...
2K
LIFES A GAS
L
