Discuss Mains water flow rate 2 litres lower than the rate the boiler can heat. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
coldboiler
If the flow rate at your cold mains tap is 12 liters per minute measured with a measuring cup and you get a combi gas boiler that can heat water at 14 liters per minute what effect will it have on the boiler?
I may be able to upgrade the mains lead water pipe at some time which would increase the water flow, but if I can't do it straight away what difference will it make?
But water will be hotter as boiler can lift 14 lpm by 35c so 12l by about 41c?
(14/12)*35
It's not a problem.
What will be a problem is if you're only getting 12l/m through the stoptap, and running a cold tap starves the boiler.
Reply to Mains water flow rate 2 litres lower than the rate the boiler can heat. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each...
Hi, Just checking I'm not talking rot. Today I visited a house with a Baxi 228 combi boiler. The technical spec for the DHW output is shown in...
1K
Hi, We have a Kinetico 2020c HE Water Softener, fitted in 2008 in our loft to the cold water tank in a vented system with a conventional boiler...
1K
