Discuss Marflow PL8 Bracket Hole Cut Out in the USA area at PlumbersForums.net
Just about ready to fit wall panel over this bracket, instructions say 50mm cut out around pipes, this seems a bit excessive, can anyone advise if i can go smaller than this?
It looks like they're suggesting 50mm when using tiles, perhaps to give a grout gap to match that of the tiles.
If you are drilling a panel I don't see why you shouldn't go for a smaller clearance, as long as there is some.
Reply to Marflow PL8 Bracket Hole Cut Out in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
