Discuss mears calculator on ebay in the Plumbing Jobs | The Job-board area at PlumbersForums.net
You can tell it's being sold by a tight fisted ferret molester.
"Eee, Ah'm not posting that! You bluddy come collect.
Eeee by gum!"
Ive metric one , they are brilliant but never used it, i seem to use the apps on my phone more but i treat the mears like an immersion heater , its there if ive a breakdown
What app do you use kris ??
The mr combi ones i use , but there are a few different ones, radiator sizing app is good, the boiler sizeing app , i also use the mr combi gas rate app and the working out the gas pipe size its brilliant, ( well its not really as it tells me to use inch pipe ,,,, booger)
Kris which one is the boiler sizing app?? I've searched but can't find it cheers
Reply to mears calculator on ebay in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hay, I'm learning fault finding in CH systems which I'd need help with, please. I've been given a set example: have got hot water but heating...
1K
Ive got a new replacement boiler to install and the Energy Saving Trust whole house boiler sizing is no longer being allowed to be used to...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I...
Hi there, I have the following system boiler setup with a low loss header and four different circuits. I've set the boiler flow to different...
2K
