T
timtyrrell
Hi
In my old house (typical london terrace) I had a conventional system with condensing boiler ground floor, big cylinder on1st floor and cold water tank in eaves on 2nd floor (loft extension)
I had a 4bar negative head pump next to the cylinder on 1st floor which fed showers on 1st and 2nd floors - the showers were great and I had loads of hot water (showers all connected with 22mm pipe from pump)
I am refurbishing a very similar property (normal terraced house to which i'm adding a loft extension) at the moment to move in to, and my contractor is really trying to sell me on a megaflo system, but I am worried it won't give me the same shower performance as I have at the moment, espeacially as I want to add a water softner to the set up this time (thinking a mini kenetic b....)
No matter what, I would also like to put all the heating components in the 2nd floor so - boiler/cylinder or megaflo /pump and cold water tank/water softener as there is some dead space up there which this would be a perfect use for. Can this be done with all the bits on the same level? Can pumps be used to sort things out as I know the cold tank usually needs to be above the cylinder. Thought almost anything could be done now adays
As for the megaflo from everything I have read, I am worried it won't give as good a performace as I have now as from all accounts you only get out what you put in. Ie. if its 2.5 bar mains pressure (roughly right for where we are in london) going up to the top shower will be weak as its going to lose 1 bar by the time it gets there, also at peak times when everyone on road is having a shower/bath the pressure will be less......
Really appreciate any thoughts you might have....
Cheers
tim
Cheers
tim
