Discuss Need to replace Myson TRV 2 Way Thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Chew
Don't know how hard this is, so any advice on whether this is the sort of job a plumber should do please let me know. I am a competent novice.
Where might I find instructions for replacing a broken Myson TRV 2 Way Thermostat on a radiator?
Depends on the type of system, you need to drain down and then remove the old one and fit the new. Add some inhibitor if you wish and then refill and check for leaks.
If its just the head thats broken unscrew the old and put on the new with no need to drain the system.
Thanks plumberdarren,
You were spot on - thank goodness i didnt get a plumber in to do that! You probably saved me £60.
Sorted
Depends you can buy fernox inhibitor in a tube which can be injected through the bleed screw (with trv and lockshield on each side of the rad shut) instructions are on the tube when you buy it or do you already have a different brand?
no darren, just asking in general. heard best was with towel rad but was wondering if not got a towel rad what was best way. thanks mate. does it advise on how much to use? or is just a full container?
thanks alot mate. so would the best way for example be re-fill the CH system, but leave a rad closed,then inject through rad bleed valve,when all in, open TRV and LSV? Sound about right?
Reply to Need to replace Myson TRV 2 Way Thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know...
