Discuss new bloke in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Reply to new bloke in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I recently purchased the ground floor of a detached Victorian property in Dorset. As part of the refurb, I will need a new boiler and about 94m2...
Hi all. Not sure if it's a plumbers job or another trade but thought I'd ask. I am installing a new toilet downstairs next to an outside wall...
Hi, Is it normal/usual or acceptable for there to be this much metal filings in a heating system following a new boiler installation only 5 weeks...
Hi I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect...
Plumber had fitted a new mono kitchen tap. The hot water takes ages to get hot if at all. The on lever hadn’t much turn on it and it’s at full...
