Discuss New kitchen tap - mixed pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
emellodew
I am looking to purchase a new kitchen tap as part of a kitchen replacement.
My system comprises of gravity fed hot water, about 0.5 bar (based upon height calculations) and mains fed cold water. I was thinking of going for a mono bloc tap, but am unsure if this would work with a mixed pressure system? Would I be better of going for a normal tap with two separate valves on? Or am I completely wrong in my thought and forefather option should look to equalise the pressure by reducing the flow to the cold tap?
Any help appreciated.
Ed
Check the specs before you buy. Buy a tap that is suitable for low pressure from a reputable company.
Reply to New kitchen tap - mixed pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had a plumber fit a new mono block kitchen tap. The water runs very slowly now. Also, not sure if this is to do with it, but my hot water...
Plumber had fitted a new mono kitchen tap. The hot water takes ages to get hot if at all. The on lever hadn’t much turn on it and it’s at full...
Hi everyone, Gas combi Boiler Mains fed in all taps and shower How do I balance the water pressure in all faucets in my flat. Every tap/water...
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I...
