Discuss Next door's flue is making a gurgling noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Milomouse
Hi
Next door's flue is making a scary gurgling and popping noise - they're away for Easter so we can't go round, does it sound dangerous to any of you professionals? :eek:
Thanks Hilary
Hi Hilary
Thats a very strange noise, it sounds like water running down a waste/soil pipe.
Never heard a boiler make that noise before im afraid.
I know what it is :D
And no will just lockout but needs sorting
Needs a service and a clean as soon as they get back
Hi
No neither have we it's definitely their flue as you can hear it and see fumes when their boiler fires up - at first we thought it was ours but now I'm not sure what's worse - we can switch ours off
Anything they can do or anybody they can ring in the meantime?
as its not there property no other than if its rented or maybe building management (if they pay a yearly charge) sorry
  • Informative
Reactions: Dan
o_O So it's not dangerous? The property isn't rented it's owned by next door but as they're are away and we're semi-attached to them I'm a little worried as every time their boiler ignites the noise is getting worse
Thanks Hilary :)
Got one of these by the sounds of it.
When are they back?
Looks like a flat so most probably a combi, the only reason it would come on during daytime is if they forgot to turn down the room thermostat. You can save them a few ££ by turning off their gas supply at the meter, looks like the type of property with banked external meters.
Thanks Hilary :)
no, wont blow up or cause an elec fire
Good thinking batman!
but write a note / letter through the door telling them what you have done and why
  • Agree
Reactions: Dan
As shaun says best put a note through the door just in case you miss them on their return . Regards kop
  • Agree
Reactions: Dan
Hi Thanks for all your replies, yes it will be a combi boiler, we're a 3 story house and if it's all safe I'll leave well alone :)
Thanks again Hilary
  • Informative
Reactions: Dan
Keston boilers usually make that sound when installed in a basement and the condense runs back down the flue.
Reply to Next door's flue is making a gurgling noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
