Discuss No flexi, soil pipe into the stack possible? in the DIY Plumbing Forum area at PlumbersForums.net
Hi chaps,
I’m installing wall hung toilet with a frame. I’m looking to run waste pipe without a flexi, but can’t figure out what’s on the market that will do that.
The waste on the frame is 90mm and has grooves for attaching into the frame and my soil stack is 110mm. I’m out by about 50mm depth and 80mm in hight, but for the life of my can’t find any solid connectors that would allow my to run the waste pipe.
Any advice would be much appreciated.
Cheers,
Lumen
They do a straight adapter then all you need is a street 90 soil bend
Yes the frame manufacturer where you bought it from should be able to help in regards to the straight adapter
Depends how much you might be able to get away with either a street 45 or another street 90 up
Found it.
Roca UK after sells support were excellent and advised in few minutes over the phone.
If anyone else looking for one, here’s the part number: 892028000
Thank you all for your help.
Reply to No flexi, soil pipe into the stack possible? in the DIY Plumbing Forum area at PlumbersForums.net
I'm a DIYer and have a problematic toilet setup to fix: The waste pipe was installed too high for waste to flow out from a standard toilet...
This is a follow-up to my earlier post Fitting a cistern (with frame) into a stud wall (100mm) (follow-up) and also to this post Can i connect...
Hi I’m trying to find something that will connect a geberit 90mm toilet waste pipe into a standard 110mm soil stack. The geberit cistern came...
Hi, When running 50mm waste to the stack, how do I get it so the 50mm does not have to be so far from the wall? As the offset at the stack...
