Discuss Noise Coming from Loft Water storage tank? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wild nomad
Hi there,
Just had the following email from one of my customers:
''we have a very loud noise coming from the loft like an underground train. It is intermittent but quite alarming at times accompanied by a banging noise.''
This is about a month or so after I installed a new CWSC and F&E tank. All building regs and British standards were adhered to. It sounds a lot like water hammer to me.
The old float valve they had was letting by some what so the new one maybe causing water hammer because it's working too well. I could look at putting in more clips and an arrester but since I can't get round to look at it till the weekend thought I'd have a brain storm with you guys and see if anyone can think of what it might be if it's not water hammer.
Thanks in advance :)
Might need a few more clips. I had a new one that resonated, fitted a bit of 3 x 2 and a couple more clips and it was sorted.
I know its new but it wouldnt surprise me that the diaphragms went already, wouldnt think so but you never now , or it may be the stopcock hammering , is the stopcock new or is it the original one ,
Yes, original stopcock located in the kitchen.
No i mean stopcock to isolate the tank in loft ? soz
Sounds like the ball valve is oscillating, close the incoming stop valve slightly to reduce the incoming flow, otherwise use a larger ballfloat or damping plate fitted to the ball valve lever, alternatively baffle vanes fitted inside the cistern to prevent waves from forming
Reply to Noise Coming from Loft Water storage tank? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hi, I wonder if you could help me. The overflow pipe drips intermittently from the large cold water storage tank in the loft. Not the small F and...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Hi. Please can anyone help. My mum has just sent me this video of her airing cupboard. She had put the imersion heater on to warm the water for a...
1K
Hi all - hoping someone knowledgeable can help as I'm super confused by this.... I have a standard system / gravity fed boiler, large cold tank...
Deleted member 120897
