Discuss Old radiator bleed valve key in the USA area at PlumbersForums.net
Does anyone know what key is needed for a bleed valve like this? None of the ones I have seem to work
Really old either stelrad super or myson single .
If key won't go in just file it down if bit slack on air pip tap key with hammer (needs to be brass key)
Could useful scrap out excess paint .
As above needs to be brass with a reduced thickness end, not the cheap and not so cheap sometimes, cast alloy.
Screwfix or Toolstation or a file.
Reply to Old radiator bleed valve key in the USA area at PlumbersForums.net
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
I bought the a bleed valve from S****fix about a year ago: s****fix.com/p/radiator-vent-blanking-plug-nickel-2-pack/40972 It worked fine...
When I turn on our CH there's a lot of noise from one specific part of the system - the pipes on the landing, and one radiator. It sounds like...
2K
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
