Discuss Outside pipework and connections in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Firstly, Im not a plumber but like to tackle anything in my own house.
I want to plumb in a USA type fridge to the cold water supply in the kitchen. The floor is tiled and i dont want to lift them. The best route is outside through the kitchen wall under the sink.... under the decking fir 10ft...then back into the house where the fridge is. The pipes would be almost entirely hidden under the decking.
I was going to use 15mm plastic pipe with insulation, instead of copper and compression fittings instead of plastic. Any issues with this? Any advice welcome! Cheers!
Yes will freeze and cause issues
Even with the correct thickness of lagging? Sorry for my ignorance but it's rare to get sub-zero temperatures where I come from so people tend to go a bit lighter on the lagging compared to the UK.
Yes this last week has been mad 11/2 waste pipes freezing
Understood.
There are burst pipes galore over here after 3 days of sub-zero temperatures. It actually made todays newspaper because it is really quite unusual for us. When I was working out on site instead of a workshop I only did 2 0r 3 frozen pipe bursts in 5 years.
MaksimsK's suggestion of a heat trace might be the way to go if there are no internal routes then?
My opinion it would be the very last option/ only way
Or do what we did and buy a fridge you can fill up yourself ..........
Good advice, thanks guys! Never heard of the frost protection trace heating kit before. Thats the way to go, as there's no way of running a pipe inside the house without lifting tiles....and its my sons house and he bought a non-fillable fridge.
Trace Heating is designed for other things.
I personally would not use it on a drinking water supply.
If the pipe has to run outside the property, it should be done using the correct materials and be buried at the right depth.
Reply to Outside pipework and connections in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and...
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi I have a question, I want my flat to be separately connected to the mains water supply for water coming into my kitchen and bathroom instead of...
Hi guys question about saniflos đź’© I'm working at a property that the entire place was fed off a sani, that's packed up, blocked the line entirely...
