Discuss Outside service pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kieren
We live in a rural area where our service pipe runs from the road under two fields and into our house. In April a section of the pipe sprang a leak which I had a company out to fix, south west water paid £100 and i paid the princely sum of £400....
Anyway we have just been told by our neighbour that it looks like the pipe is leaking again from a new location.
What i'd like to know is how difficult it would be for me to fix. The pipe isn't deep maybe a couple of feet, the last time the company got a digger but it was like the somme so I couldn't blame them for that.
I was thinking of digging down, having a look at the pipe, seeing how big the hole/leak is, measuring the pipe, cutting out the affected area and fitting a compression coupler joining the 2 pipes back together.
Does that seem reasonable? I figure that at the very least i would have saved a bit of time by digging the hole for them. If I went ahead what tools do you think I would need, save shovel and coupler.
Many thanks.
Consider, is it a shared pipe and is the leak on your land?
The hardest thing is finding the exact location of the pipe.
It's not always directly below the leak.
You may have a bit of digging to do.
Is it metal or plastic pipe? Could a pinger be attached at the end for use with a pipe tracer? Specialist pipe tracing equipment can be hired or if metal maybe a simple metal detector might help in finding the pipe.
If it comes to replacing a lot of length need to be sure their aren't other services next to the water pipe. Moling might be cheaper than digging, at least check out.
Reply to Outside service pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
