- Messages
- 5,439
But not together haha...
Couple of questions..
1. There's an overflow pipe run into a boss on a soil which has come loose. Not sure if right adaptor was used. What's the correct fitting to connect an overflow pipe to a soil pipe boss? The boss is already there, I just need to connect overflow to it.
2. I've fitted isolation valves (non full-bore) when swapping/adding rads to systems where the water is traditional vented pumped heating. I know you're not recommened to because of reduced flow but so far every time the rads have got hot with no probs. Done it about 4 times. Have I just been lucky or is it actually quite unlikely to actually cause a problem?
