Discuss Pipe Centres too Narrow for Bar Shower in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello,
I’m having a bit of an issue trying to fit a mixer shower bar, the pipe centres are around 3/4mm too narrow! I’ve attached a photo below, is there a simple fitting I can by to narrow the pipe centres by a few mm?
Are the wall ones 150mm centres ?
Can you undo the screws and push the pipes apart
Your fecked then would see if you remove the mastic if you can move the pipes then
An experienced plumber will know how much 'persuasion' the pipes can take and I'd imagine with mastic removed and a little prep that that difference can be persuaded.
If not then im afraid its nocking out some tiles or cutting access from behind
I have a plumber coming tomorrow to have a look. I’ve also bought the below as a back up as it says the centres are adjustable +/- by 25mm
Reply to Pipe Centres too Narrow for Bar Shower in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
