Discuss pipe centres in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
T & H Plumbing
Anyone have an idea what pipe centres will be for a 600 wide towel rad???
Yeh 555 to 565, so go with destroyers 560mm
Reply to pipe centres in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Similar to radiator dT's, is there a way to mathematically calculate the UFH pipe centres required to satisfy a given room's heat demands...
Hi all. The current towel rail is 1000mm x 600mm and ideally I'd like the pipes coming straight from the ground into the rail. The distance...
This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not getting through to the boiler. The...
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it...
Hi - I want to replace Aqualisa power shower to mixer shower to a std. mixer shower, however, the centres for the hot and cold are only 65mm. I’ve...
